Tom's Hardware > Forum > Systems > Dell > Having problem updating XP on new system?
Forum Systems : Dell - Having problem updating XP on new system?
Archived from groups: alt.sys.pc-clone.dell (More info?)
I was wondering what the work around is for the update Win XP icon that
pops up and says I have updates but when I click on that Start Download"
the option just disspears. I have the dial up configured but it don't
want to d/l. Any help would be welcomed. I check the ones I want to d/l
and check them but I can't go no farther.
Thanks
Sponsored Links
The best work-around is a broadband connection! :)
"devans" <devans@nnemonet.com> wrote in message
news:6MXcc.379$A_4.22@newsread1.news.pas.earthlink.net...
> Thanks
Reply to Anonymous
for those with only dial up connections i suggest that you
start-mycomputer(right click)-properties-automaticupdate(tab)-uncheck 'keep
my computer up to date...'
when you have time to download simply point your browser to
windowsupdate.microsoft.com and follow prompts.
clicking on the 'start download' popup that appear in the tray will start a
background 'trickle' (slow) download of the updates followed by a 'new
updates ready to install' once they are captured to your computer.
> Thanks
Reply to Anonymous
devans <devans@nnemonet.com> wrote in message news:<6MXcc.379$A_4.22@newsread1.news.pas.earthlink.net>...
> Thanks
This may save some downloading time:
http://www.microsoft.com/security/protect/cd/order.asp
Cheers,
Ned
Reply to Anonymous
I already have that ordered and I see it's on the way. It's the
remaining patches I was wondering about. I went to Microsoft's webpage
and d/led the critical patches first but when it d/led it come back
failed install on the 6 or so listed. I don't know why I can't d/l them.
>>Thanks
> Cheers,
> Ned
Reply to Anonymous
are you logged on as administrator?
news:4afdc.1792$A_4.780@newsread1.news.pas.earthlink.net...
> >>Thanks
> > Cheers,
> > Ned
Reply to Anonymous
devans <devans@nnemonet.com> wrote in message news:<4afdc.1792$A_4.780@newsread1.news.pas.earthlink.net>...
If they are downloaded but not installed try installing each one on
it's own by manually visiting Windows/Office Update Site. Restart
between each install.
Good luck,
Ned
Reply to Anonymous
or perhaps this might help...
http://support.microsoft.com/defau [...] -us;331663
"Christopher Muto" <muto@worldnet.att.net> wrote in message
news:Iefdc.255$d8.215@nwrdny01.gnilink.net...
that
Download"
don't
d/l
> > >>Thanks
> > > Cheers,
> > > Ned
Reply to Anonymous
There are 566 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
