Hello everyone, I have been trouble with my Toshiba. It has lately been shutting off and not turning on. The timer light is flashing in a code and I was told the capacitors are bad. its 3 flashes then a pause.
I was wondering if anyone can tell me how to replace the capacitors, how much are they, where can I buy them. Or is this even the right code? Or is it something else.
The model of the TV is a Toshiba-42HL196 Chassis # TAC0604
Thank you.
Thank you.
