Tech: Removal of MM Draw bridge Gear from Shaft.
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I have a MM whose final gear(which drives the drawbridge and switch arms) is
slipping on the shaft. I can get the shaft out, but how do I remove the gear
from the shaft, is it threaded on?
G
Guest
Guest
Isn't there a set screw on it ? Probably an allen head. LTG :)
"Will" <neogeoreo@hotmail.com> wrote in message
news:tW5se.1705881$6l.1550884@pd7tw2no...
is
gear
G
Guest
Guest
It is just pressed on, the shaft is round and the hole is the gear is square
(started out). It should not be that hard to get off if it is slipping. You
will most likely need to epoxy the gear to the shaft because the gear is not
available.
Tim
>is
> gear
G
Guest
Guest
Thanks for the info. The root of my problem was the switch arm was becomming
stuck on the down switch, causing the mechanism to seize. Adjusting the
switch away from the arm fixed it.
"Pinball Parts Plus" <PinballPartsPlus@comcast.com> wrote in message
news:2cGdnQaWYJGvaS3fRVn-3Q@comcast.com...
square
You
not
> available.
> Tim
> >is
> > gear
