Tom's Hardware > Forum > CPU & Components > CPUs > What do you think about these parts for me new PC
Forum CPU & Components : CPUs - What do you think about these parts for me new PC
Hello, I am going to by myself a new computer dont have much money though... :(
I was thinking about these parts would you please be so nic e to tell me are they good?I just wanna get the "Best bang for the buck" kind a PC you know...
Abit Socket A NF7-S, nForce2 chipset, ATX
AMD AthlonXP 2000+ (1667MHz) 256KB L2 cache 266MHz Bus 0.13 Thoroughbred+Spire Whisper Rock III
2xDDRAM 256MB PC-2700 333MHz CL 2,5 Kingston
Western Digital Caviar WD800JB 80 GB 7200rpm 8MB cache
Hercules RADEON 3D Prophet 9700 PRO 128MB DDR, AGP 8x, DVI, TV-Out
These are the main parts I was thinking.I thought that Troughbred "B" is really good to oc thinking to get the XP 2000+ 2200Mhz or so......
Tell me what do you think about this rig..
Sponsored Links
Why not ASUS A7N8X Deluxe?
Maxtor Diamond Max Plus 9 (8 MB Buffer) HDD's are good WD alternative
<b> "You can put lipstick on a pig, but hey, it's still a pig!" - RobD </b>
Reply to Spitfire_x86
asus is to expensive for me !
Reply to pots4t4j4
The Epox 8RDA+ is also an excellent alternative..with plenty of room for OC...
Very good spec
Reply to pardal51
Good specs with the hardware!....the only thing I would change if it were mine would be the memory selection and the motherboard. I would go with corsair xms pc3200cas2 and for the motherboard I would go with the Epox8RDA+ as the guy mentioned before....this motherboard is great for overclocking...the regular version (8RDA) is only like 88bucks on newegg if you dont want raid etc..
<font color=green>Cars are for people who are scared of riding on two wheels</font color=green>
Reply to Civilized
the nf7-s is brilliant.I have got one for my xp 2400 and the overclocking options are great and i have had no problems with it.It's got serial ata raid too, which the 8RDA+ doesn't have.
no matter how hard you try, you can't polish a turd. :]
Reply to ad_rach
Never EVER buy CL 2.5 DDR Ram.....
ur better off just buying PC-2100 CL2 than PC-2700 CL 2.5
whta you SHOULD do is get some CL2 PC-3200 DDR Ram....that way u cna overclock without worrying about ur ram becoming unstable....
<A HREF="http://www.anandtech.com/mysystemrig.html?id=13597" target="_new">-MeTaL RoCkEr</A>
Reply to MeTaLrOcKeR
There are 560 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
