G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a Dell 4550, using Windows XP. I just had to replace the hard drive.
The installation went fine except that I have not been able to load two
programs: Paint Shop Pro 9 and SnagIt. I just cannot get either program to
work. When I run PSP, nothing happens - no new screen comes up (however if
you go to the Task Manager, it does show PSP as running). With SnagIt, at
least I get a small window to come up, but all it has in it is a yellow
triangle with a big exclamation point!
I've uninstalled and reinstalled both programs several times to no avail.
They both worked fine before the old hard drive crashed and I had to put in
a new one. Anyone have any ideas?
Tony
Tony
