configuring a GX620
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I'm trying to configure a GX620 with dual monitors
My company will not buy anything but what comes from Dell so which video
card option should I pick so the dual monitors works the bs
1) integrated video, Intel GMA950
2) DVI (Digital Adapter Card, full height
3) PCIe 128MB ATI X600SE
I'm trying to configure the system with two Dell 19 inch ultrasharp 1905FPs
G
Guest
Guest
OK reading more the GX620 does not support dual video
what system should I get if I want dual video?
> video card option should I pick so the dual monitors works the bs
> 1905FPs
G
Guest
Guest
"William Kossack" <kossackw@njc.org> wrote in message
news:11dsqiarhrsu7c0@corp.supernews.com...
It's not the GX620 that you need to worry about it's the video card and
drivers. I believe the ATI X600SE supports dual monitors. You can go out
to ATI's website to verify.
Rob
G
Guest
Guest
the problem is picking a video card from the dell site that supports
dual video
I don't see the ati card on the selection list
>Rob
G
Guest
Guest
I found a posting from dell saying
First, let me apologize. This X600SE for Optiplex video card was never
intended for dual monitor usage and shouldn't have been sold under this
pretense. The only dual display functionality is the following:
- CRT and TV = VGA connector with DVI-I-to-VGA adapter and S-Video connector
- DVI and TV = Dual Displays DVI-I and S-Video connector
so you have to connect the second monitor via s-video
>Rob
G
Guest
Guest
ah sorry there it is
> dual video
>> and drivers. I believe the ATI X600SE supports dual monitors. You
>> can go out to ATI's website to verify.
>> Rob
G
Guest
Guest
news:11dss6u3ventl71@corp.supernews.com...
> connector
Interesting, I read the same post in the Dell Forums. Before I gave up on
it I'd go get a dual monitor Y cable and the proper drivers and see if it
works. Many times Dell says things aren't available not because its not
capable but because dell hasn't approved it e.g. the dual monitor capable
driver.
Just a thought.
I have a low profile 620 coming in a couple of days and if I can drum up the
cable I'll try it out.
Rob
G
Guest
Guest
>>connector
>driver.
>Just a thought.
>Rob
so which video card should I use with the GX620 and dual monitors?
