Sign-in / Sign-up
Solved
PC Laptop battery light
  • Battery
  • Light
  • Laptop Battery
  • Laptops
Last response: in Laptop Tech Support
December 16, 2009 9:38:57 PM
When I plug in the power supply to my laptop the amber battery light flashes like mad as. The AC power also flashes green like mad.
I bought a replacement battery and that worked fine untill it ran out of juice. As soon as plugged in the charger the lights went crazy.
Does anyone have a clue as to what causes this and how to fix it?
More about : laptop battery light
December 17, 2009 12:50:45 AM
Does the machine boot without the battery in? Bad battery at any rate.
m
l
December 17, 2009 4:45:10 AM
No it does not boot.
However it did boot up with the replacement battery and ran until the was drained.
Then I plugged in the charger and the lights kept fleashing.
m
l
December 17, 2009 4:46:28 AM
m
l
December 18, 2009 3:21:45 AM
The original battery and charger worked for 3 years with no problem.
I tested the charger and the output was 19V as required by the manufacturer.
I then removed the battery and plugged in the charger and the amber battery light still kept flashing as well as the green AC power light.
I hope this additional info gives you more ideas as to my problem and possible solution.
m
l
December 18, 2009 1:07:51 PM
If the laptop doesn't boot without the battery then looks like you have a power problem in the laptop (as indicated by the flashing lights). The easiest thing for me would be to look into replacing the mainboard.
m
l
December 19, 2009 10:14:08 PM
Many Thanks,
I took it to Toshiba repair shop and low and behold it was the charger that was no good. So $60.00 later all is well. I appricate your efforts.
I asked how much it would cost to replace motherboard and they said about $300-$400.
Thanks again
m
l
Best solution
December 21, 2009 1:58:24 PM
Actually it can be half that if you do it yourself. Maybe less than half that.
The power supply was bad? Interesting. I've alwyas. . no I take that back, my father-in-law kind screwed his up, but I've never experienced a bad one. So this makes two in the past 11 years.
