Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi Friends,
I formatted and re-installed Win XP,but this time eveything appears so big at 800x600 while it becomes too small at 1024x768.I need something inbetween,but unfortunately there's no option available.In the previous XP everything was working fine.And secondly,the Win XP does not allows me to register my O.S saying I've exceeded the no. of installations allowed..so what I need to do.Please help me guys if you can.
Thanks
Mick
Your video adapter drivers probably need to be reinstalled.
Visit the support web site of the manufacturer of your video
card adapter and download the latest drivers.
Before installing them, uninstall the old drivers. In your
Control Panel, open the Add or Remove Programs applet
and look for your video drivers to uninstall.
If you happen to have a notebook computer, visit the notebook
manufacturer's support website to download the correct video
adapter drivers for your specific notebook model.
After installing a fresh set of drivers, right-click on your
desktop and select Properties > Settings, change the Color
Quality to "Highest (32 bit), then adjust your Screen Resolution
to your liking, then click on Apply.
| Hi Friends,
| Thanks
| Mick
| mickscool
Ignore the advice about video adapter drivers. As usual this MVP isn't
always. You can adjust the size of almost everything in the DISPLAY,
Properties, Appearance TAB, Advanced. I recommend that you use the 1024 x
768 setting and simply select larger fonts and icon size to compensate for
the added resolution.
