No HDMI Signal in monitor (new build )
I added speakers to my computer and now I have this message on my monitor "HDMI NO SIGNAL"
Everything seems to be working etc. I can get on the Interenet, play viedeos, email and all software is useable. How do I get that message off of my monitor?
1 answer Last reply
More about hdmi signal monitor build
  1. Can you check the options on your monitor. This will most likely be a problem with the monitor and not your computer itself.
    Are you using HDMI or DVI?
Monitors HDMI New Build Windows 7
