My tv antenna (inside) is not picking up signal all of a sudden
  • Digital TV
  • TV
  • Converter
  • Home Theatre
Last response: in Home Theatre
February 8, 2011 12:43:33 PM
My indoor converter box is on and my antenna is on, but when I turned the tv on this morning I see the tv channel, but there is a message that there is no signal. I don't have digital tv or a digital converter box.
Please help.
More about : antenna inside picking signal sudden
February 8, 2011 8:31:37 PM
what you need to do is check the other channels and see if all of them are broken or just one.
perhaps the channel is experiencing technical difficulties or upgrades or whatever.
let us know if its only one channel or more than one.
m
l
February 15, 2011 11:12:16 AM
Hi Apprentice
It's all of the channels. I even did a channel scan. Can you think of anything else? Thanks! Belladonna0926
m
l
March 26, 2013 12:37:12 AM
I think you should install a digital antenna to get all channels properly. With the digitization of broadcasting system, it is now mandatory to use digital antenna to get perfect picture and sound quality.
m
l
July 16, 2013 11:50:41 AM
The same thing just happened to me! All my 4-1 6-1 ect are gone. All I get is a comcast channal 13-1...all my digital over the air channals are gone! I've changed nothing. Nothing is broke. Connections ate all tight...just woke up to it this way! Wtf
m
l
July 16, 2013 11:50:42 AM
m
l
December 6, 2013 5:44:05 AM
I just had the same thing happen. All of the OTA channels worked for months, and then suddenly there is nothing. I am in an established neighborhood with no new construction. Same condition on all TVs in the house. I checked the antenna in my atick and it is connected and pointing in the right direction. What gives?
m
l
March 24, 2014 8:12:31 AM
Did anyone ever find out what happened? Did you ever get your channels back? Cause I was getting 15+ channels and now I get none either. And nothing has changed equipment wise or tower wise. Just wondered if anyone solved the mystery.
m
l
April 3, 2014 9:26:55 PM
Yes.ย  I have the cable connected to the antenna throughout the house and the cable company I have my internet service with (Comcast) had been supplying the local stations through the cable.ย  I don't think the antenna was actually supplying the signal.ย  It was coming through the cable along with the internet.ย  Comcast just began scrambling the local signals.ย  We reran the auto channel set up on our TV and only got two channels, both from Comcast, saying they scrambled the local channels and they would rent us a box for each TV to unscramble the local channels.ย  I separated the signal coming from Comcast running it to my modem for internet.ย  Then I reran the auto channel setup and got most of the channels back once it was coming only from the antenna.ย  I also installed an amplifier in the antenna cable to boost the signal and got the rest of the channels plus a couple that I didn't have before.
m
l
May 12, 2014 7:43:37 PM
I'm an antenna installer, and it quite often occurs that all the TVs are suddenly not receiving a signal, but the antenna is intact. The most common reason I find is that antenna has an amplifier attached to it, which requires a power source, and most commonly this has been turned off, unplugged, or removed. It goes behind one of the TVs, and plugs into a TV point and needs a power point to plug into for the power. If it is missing, then you need to buy another, usually available from an antenna retailer, like Alvin or Laceys. ( I live in Melbourne).
m
l
May 12, 2014 8:20:00 PM
i dont know if it's applicable elsewhere, but a while ago in Australia they turned off regular analogue TV signal completely and are only broadcasting the digital signal. Also from time to time you need to re-tune all your stations, try that.
m
l
July 1, 2014 5:59:28 AM
Hi there
I am UK based and 1 week ago I was plugging in another tv in the house where a tv had previously been in and working.
Upon plugging it in it worked the first time and then I reseated the the brackets on the back of the tv and plugged it back in. The digital tv signal then stopped on all channels.
I have a mast splitter and a booster located in the house. The booster is still providing the DC voltage through the RF cable up to the mast and I replaced the splitter on the roof with still no results. I have also turned the booster on and off and still nothing.
Any suggestions?
m
l
July 1, 2014 9:37:08 AM
EddyW said:
Hi there
Any suggestions?
I think you may have the booster installed in reverse. The way my booster works is it takes a signal received normally through the antenna, amplifies it, and then pushes it to the television. An antenna can only receive and amplify whatever signal is out there and make it stronger where it reaches a TV, not make the antenna stronger in receiving signals that don't reach your antenna already. If you are pushing a DC current to your mast antenna, that doesn't sound like what you want to do.
m
l
July 2, 2014 1:55:46 AM
Infidel1 said:
EddyW said:
Hi there
Any suggestions?
Ok, so why was it working previously and has now stopped working? Can you advise on what to get / to do to resolve this?
m
l
