Replacement R3000 DC cable
Last response: in Laptops & Notebooks
Anonymous
a b ) Power supply
a b D Laptop
December 21, 2009 5:16:30 PM
Does anyone know where I could obtain a new internally connected DC cable for a Compaq R3000 AC Adapter / Power supply?
Thank you in advance
Anonymous
a b ) Power supply
a b D Laptop
December 21, 2009 6:06:04 PM
If I've identified your model correctly you can buy replacement power supply cube (not Compaq-made probably) for around $30 on e-bay.
Alternatively, replacing just the DC cord depends on whether the plug which inserts in the laptop is a standard type -- they usually are.
A visit to an electronic enthusiast store (with the laptop) would probably secure a plug of the right type and a suitable length of wire. Then it's a fairly simple soldering job, assuming you can open the Compaq cube.
