G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi guys
Actually, I'm so pleased to be able to ask for tech help, because that means
my Gottlieb 1974 EM is functioning for the first time after a one year
restoration (I work very very slowly ... cabinet repaint, clearcoated PF,
etc!)
So ... there are heaps of quirky problems that I won't bore the group with
(yet) ... will try to figure them out myself first (lights on, that
shouldn't be on; points being awarded that shouldn't be awarded, etc etc)
BUT ... the one that I just can't seem to fix is the weak left flipper. At
best it will get the balll about half way up the playfield - not strong
enough to drop a target!
I've read Clays guide, and have a Henk de Jager's pinball repair and
maintainance book and have tried the following:
new EOS switch
adjusted the EOS switch
replaced coil with nice new coil
adjusted spring (not too tight)
swapped coil stop (with the flipper that works well)
.... no luck.
Any help would be much appreciated.
I'm not too worried about the other faults as I can take my time fixing them
and learning about fixing them (hell, you can see I'm patient ... it took me
a year to get this far), but the weak flipper is annoying because I can't
really play the game properly!
As a small aside ... even with the faulty flipper I just love this machine
.... the kids love the machine. After a year of tinkering (and having bits of
it all over the house) I can't believe it actually works (never mind the
small 'glitches'). When I heard the free game knocking sound for the first
time (since about 1975) ... priceless.
Cheers
manny
Hi guys
etc!)
new EOS switch
.... no luck.
Cheers
manny
