Dell wont power on and no power lights can i fix this
dell latitude is dead no power no lights try taking battery out still no good
3 answers Last reply
More about dell wont power power lights this
  1. if no power lights / no diag lights then you have a few issues. Try taking it to a shop and asking them to plug it in (or if you know someone with another latitude laptop use their power supply).
    If that doesn't work, the power connector inside the laptop may be broken. Your looking at $80-150 to fix this.
  2. thankyou!
    can this be fix by me if i got the part
    would it be easy to do ?
  3. You would have to solder the part on the motherboard. If your ok with opening up a complex machine and doing so go for it. Buttttt if not, i'd leave it to the professionals.
Dell Latitude Light Battery Power Computers
