I am currently having 17inch (4:3) CRT. ...& thinking of upgrading to 23inch lcd (16:9),.my question is ---- will the gaming performance get affected..I mean whether it will get slow or remain normal...
SPECS:-
P4 - 3.2GHz
RAM DDR2- 2GB (800 MHz) +512mb (533 MHz)
Intel 945GTP
nvidia 9500GT (1GB DDR2)
160 GB SATA
idt sigmatel on board (sound card)
17inch CRT
Also...I want to buy a economic+good sound card (gaming purpose as well) , as my onboard card (sigmatel) is quite annoying with vista & window 7... plz suggest me one.
plz forgive for broken language and knowledge and plz reply to my both problems thanks…
As long as the new lcd has a refresh rate of 8ms or less, you should have decent video performance. But if you switch to a higher resolution than you are gaming at now, your framerates in games will likely get slower. If you now game at 1024x768 and you get a monitor that is native 1920x1080 or so, your 3d games will run slower.
thanks
Message edited by kalaghar1509 on 11-28-2009 at 09:03:27 PM
