Laptop screen replacement Help!
About a month ago I dropped my laptop and the screen stopped working about a week later. The screen went white and scan lines intermittent came in and out. I bought a replacement monitor (an exact match) I have the screen all plugged in but nothing is happening. There are vertical lines up and down the screen, some black ones and then different colors all over. When I move the main cable hooked to the screen it goes completely white. I have hooked the computer up to a TV via the VGA cable. Everything shows up fine on the TV. This is also the second new screen I've tried in this laptop. Any ideas?
Thanks!
Here's some images:
http://img704.imageshack.us/img704/5029/dsc01093z.jpg
http://img706.imageshack.us/img706/2467/dsc01094v.jpg
1 answer Last reply
More about laptop screen replacement help
  1. Either try using another VGA cable, or another type of cable to connect your computer and monitor.
Laptops Laptop Screen
