Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > HP Power supply keeps failing
Forum Computer Peripherals : Other Peripherals - HP Power supply keeps failing
I am on my second HP power supply in a little over a year. What could be causing the power supplys to fail?
Sponsored Links
I would advise buying a power supply from a reputable power supply vendor such as Corsair, Seasonic or PC Power & Cooling (technically all the same anyway).
However, it could also be the power source the PSU is drawing from. Are you using a power strip with a surge protector on it?
Reply to TheViper
I bought the power supply directly from HP and yes I have a surge protector on the computer. Could a bad voltage regulator on the motherboard cause a power supply to go bad?
Reply to Jill_69
There are 936 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
