Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > System Restore in XP Pro doesn't work
Forum Windows XP : Windows XP General Discussion - System Restore in XP Pro doesn't work
Archived from groups: microsoft.public.windowsxp.general (More info?)
Please help! I cannot create a system restore point, nor is System Retore
creating any automatically. I tried rebooting my system, using the
check/uncheck box in system properties, using the "Run" line, and trying to
run System Restore in Safe Mode. I also tried copying the "framedyn.dll"
from the \windows\system32\wbem directory to the Windows\system 32 directory
(I don't know if it's supposed to be there or not. The only option I have
left that I know of is to reinstall Windows XP. Can anyone help?
Perly
Sponsored Links
Hi,
Please post any error messages you receive when attempting to create a restore point.
Check Event Viewer for any errors also.
Go to Start - Run and type eventvwr.msc and press enter.
Click on System in the left pane.
Click the gray title "Source" at the top of the source name column in the right pane to
sort by source name, look for "sr" and "srservice".
Double click on each of these events, then click on the button below the two arrows in the
upper right corner. This will copy the event information to the clipboard. Paste the
information for each of the two event here. This will help us in diagnosing the problem.
Here are some troubleshooting tips for System Restore in Windows XP.
System Restore Failures to restore:
http://bertk.mvps.org/html/srfail.html
System Restore fails to create an automatic restore point:
http://bertk.mvps.org/html/srauto.html
Regards,
Bert Kinney MS-MVP Shell/User
> is System Retore creating any automatically. I tried
> rebooting my system, using the check/uncheck box in
> the "framedyn.dll" from the \windows\system32\wbem
> directory to the Windows\system 32 directory (I don't
> option I have left that I know of is to reinstall Windows
Reply to Anonymous
Thank you! I will paste all error messages from now on
and I will go through the steps you recommended.
Also, thanks for the helpful URL's.
Perly
"Bert Kinney" wrote:
> Hi,
> Regards,
Reply to Anonymous
You are welcome. Keep is posted on your progress.
Regards,
>> Hi,
>> name column in the right pane to sort by source name,
>> button below the two arrows in the upper right corner.
>> Paste the information for each of the two event here.
>> Windows XP.
>> point: http://bertk.mvps.org/html/srauto.html
>> Regards,
>>> nor is System Retore creating any automatically. I
>>> tried rebooting my system, using the check/uncheck box
>>> to run System Restore in Safe Mode. I also tried
>>> copying the "framedyn.dll" from the
>>> 32 directory (I don't know if it's supposed to be there
>>> or not. The only option I have left that I know of is
Reply to Anonymous
When I tried to create a restore point, I received the following error message:
System Restore is not able to create a restore point.
Please restart the computer, and then run System Restore again.
When I checked the Event Viewer, there were only "Information" events
related to "srservice." Those messages are as follows:
System Restore monitoring was disabled on all drives.
and
System Restore monitoring was enabled on all drives.
When I navigated to the windows\inf folder, I found that the
sr.inf file was missing. What now?
Perly
> Regards,
> >> Hi,
> >> Windows XP.
> >> Regards,
Reply to Anonymous
Hi,
It appears System Restore was disabled. In the System Restore setting stop SR from
monitoring drives other than the one Windows is installed on. Now check for the amount of
free space on the drive Windows is installed on and let me know. To do so, open My
Computer and right click on the drive Windows is installed on and select properties.
As for the sr.inf file being missing, if find the suspicious. Go to Start - Search and do
a search for sr.* If sr.inf is found, what is it's location? Also, does sr.sy_ or
sr.sys appear in the search?
Regards,
> following error message: System Restore is not able to
> create a restore point. Please restart the computer,
> and
Reply to Anonymous
Hi Bert~ Thank you. I'm at work now, but will do everything tonight-- 8 PM
Pacific time. You have been incredibly helpful and I have learned a lot
during this process, which I deeply appreciate.
Perly
> Hi,
> Regards,
> > and
Reply to Anonymous
Hi~
Disk Capacity: 74.5 GB
Used: 26.7 GB
Free 47.7 GB
After perfroming a search (sr.*), there were no sr.inf, sr.sy_, or sr.sys
files to be found.
Thanks,
Perly
> Perly
> > Hi,
> > Regards,
> > > and
Reply to Anonymous
Hi,
I should have mentioned that after clicking on "All files and folder" in Search, Click on
More advanced options and put a check next to the first three options before doing the
search.
Also check to see if System Restore is monitoring any other drives.
Regards,
noraperl wrote:
> Hi~
> Used: 26.7 GB
> Free 47.7 GB
> sr.sy_, or sr.sys files to be found.
>> everything tonight-- 8 PM Pacific time. You have been
>> incredibly helpful and I have learned a lot during this
>> process, which I deeply appreciate. --
>> Perly
>>> Hi,
>>> Restore setting stop SR from monitoring drives other
>>> amount of free space on the drive Windows is installed
>>> on and let me know. To do so, open My Computer and
>>> select properties.
>>> suspicious. Go to Start - Search and do a search for
>>> does sr.sy_ or sr.sys appear in the search?
>>> Regards,
>>>> to create a restore point. Please restart the
>>>> computer,
>>>> drives. and
>>>> drives.
>>>> that the sr.inf file was missing. What now?
Reply to Anonymous
I just reformatted my drive and performed a fresh install of XP. My problem
has
been solved. Thank you so much for your help!
Perly
> Hi,
> search.
> Regards,
> noraperl wrote:
> > Hi~
> > Used: 26.7 GB
> > Free 47.7 GB
> >> Perly
> >>> Hi,
> >>> select properties.
> >>> Regards,
> >>>> computer,
> >>>> drives. and
> >>>> drives.
Reply to Anonymous
Well that's one way to fix it!!! <BG>
Regards,
> of XP. My problem has
Reply to Anonymous
Yup. And it fixed all my other problems as well. I haven't performed
a fresh install for a year and my computer was running super slow.
Now it's fresh and pristine--until, of course, I start adding all my
programs I just can't do without. Again, thank you for you guidance.
Perly
> Regards,
Reply to Anonymous
Glad to hear it. I have a few suggestions.
Create a restore point using System Restore.
Install and update a good antivirus program. Anything other that Norton or McAfee.
Install Spywareblaster, update it and protect everything.
Run Windows Update and install all Service Packs and critical updates.
Create a restore point.
Start installing your application one by one.
Create a restore point between each one, unless you know for a fact one will be created
for you.
Run each program and check for errors.
These pages will help guide you.
Virus and Spyware removal and prevention
http://bertk.mvps.org/html/spyware.html
Keeping System Restore Healthy
http://bertk.mvps.org/html/healthy.html
Regards,
> haven't performed a fresh install for a year and my
> computer was running super slow. Now it's fresh and
> you guidance.
>> Regards,
>>> install of XP. My problem has
Reply to Anonymous
There are 1111 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
