Archived from groups: alt.sys.pc-clone.dell (
More info?)
Paul Schilter > wrote:
> Irene,
> I have both IE and FireFox. You need to keep (as far as I know) to
> access the Windows Update site. I use FireFox for everything else. I
> also use Thunderbird. All my Outlook info imported into Thunderbird
> without any problem. The same is true of importing all your Favorites
> from IE into FireFox's bookmarks. I'm using Thunderbird as my
> newsreader, no problem. Now I must also say that I've never really had a
> problem with IE or Outlook, they're just more under attack by hackers
> and such.
> Paul
I also do use Firefox and Thunderbird
Firefox, I have no real problems with even though there are some sites
that do not run well or even at all with Firefox. Windows Update,
puretracks.com, pcpitstop.com and launch.com to name a few. I have used
Firefox for awhile. I did not like the original Firefox and used the
original Mozilla. I still have the original Mozilla on my computer as I
use it's Composer program to edit my website.
Thunderbird, I do like and was surprised that it imported all my
messages from OE. Eudora, Pegasus and any other email program always
crashed during the import. There is a a couple of problems I have.
1. I like to have my threads in the newsgroups threaded (All posted
responses are in the same thread.) OE did this automatically.
Thunderbird only does it in one newsgroup after you tell it to, so you
have to do it for every newsgroup you are in and when you do it, it
expands all of the messages. The option to collapse the thread is in
the view option menu)
2. Sorting of newsgroups. Unless you subscribe to the newsgroup in the
order you want, (ie alphabetical) you have to go into the Thunderbird
folder to edit the listing.
I only use OE now for checking hotmail
