I have a Dell Dimension 9200 that will not boot up, no lights light up on the front panel. I changed the power supply & nothing has changed. I pulled the I/O panel to test the switch but can't see the connections in the ribbon that is connected to the panel. I'm sure if it the switch or not. The owner was having a problem with the PC not starting up all the time so after letting it set a while they tried booting it up & it did so they left it on & never shut it off until it died & now nothing. I'm at a lose & really not a Dell fan.
Thanks
chuck
Thanks
chuck
