Yes No
Ads
Tom's Hardware > Forum > Home Theatre > Digital TV > Best TV Tunner - HELP
Forum Home Theatre : Digital TV Best TV Tunner - HELP
Hey,
I'm looking for tunner card/cards that I would use to stream/record multiple channels (aprox. 4-6) at the same time. Any ideas. Couple questions as well:
1) is it possible to record multiple channels at once?
2) i.e will I need "multiple" tunner cards if I want to rip 4-6 channels at once?
Please any replies greatly appreciated.
Regards,
B
Reply to ketrab
A lot depends on what channels you want to record. Yes, it is possible to record multiple channels at once. Will you need multiple tuner cards to record 4-6 channels, most likely.
If you're looking to record multiple channels that you would normally view with a Cable Set Top Box, then you'd either need a set top box for each channel you want to record or use a "cablecard" TV tuner. For this, you would need either a Ceton InfiniTV tuner PCI-E card (four tuners) or the SiliconDust HDHomeRun Prime (three tuners) with a cablecard from your cable/satellite company.
If all you're looking to do is record Over-The-Air (OTA) digital broadcasts or unencrypted cable channels (channels you can view without a set top box), you can do so with multiple dual digital tuner cards like the Hauppauge WinTV 2250 HVR card.
Hope this helps
------------------------------ All Purpose System Specs: GA-H55M-S2V Intel CoreI5 760 8 Gig RAM NVidia Geforce 8800GTS-640 Windows 7
HTPC System Specs: ASRock 760GM-GS3 AMD Athlon II X2-240 G.Skill 4 GB (2x2GB) Radeon HD4670 Ceton InfiniTV4 TV Tuner
Reply to Wolfshadw
There are 2000 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 23 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
