Samsung SyncMaster 2033W TFT Resolution problem
Last response: in Computer Peripherals
November 21, 2009 2:47:36 AM
Hello,
I had recently bought Samsung SyncMaster 2033 TFT 20'' monitor but it is giving me resolution problem. I am not able to adjust resolution for this monitor as my Displey settings only showing 5 resolutions i.e - 800x600, 1024x768, 1280x720, 1280x768 and 1360x768. I had tried windows vista and windows 7 but getting same problem. I had already tried to create custom resolution from nvidia control panel but it gives me the message - Custom resolution is not supported by your monitor.
http://i47.tinypic.com/mc6lmo.jpg
I am not getting higher screen resolution like 1600x900 etc which are supported by this monitor..
I have nvidia 9800GT graphics card, windows 7 64bit..
can any1 plz help me on this issue ?
waiting eagerly for reply..
Regards, super M
a b C Monitor
November 21, 2009 3:16:42 AM
Click on the advanced settings that is shown in the picture. It should give you more options.
a b C Monitor
November 21, 2009 3:18:36 AM
Have you installed the latest graphics drivers?
November 21, 2009 3:41:39 AM
Hello,
Thanks for the responce..i have latest nvidia drivers for windows 7 64bit and resolutions are same in advanced settings..
Regards, Super M
a b C Monitor
November 21, 2009 3:55:07 AM
There may be a setting in the advanced Nvidia control panel for resolution that is putting a cap on your windows resolution. I had that happen once with my ATI control center.
a c 193 C Monitor
a b Ô Samsung
November 21, 2009 12:58:40 PM
Try un-installing the drivers, reboot then reinstalling.
This fixed a fuzzy text issue with my HTPC.
November 21, 2009 1:04:18 PM
which driver jaguarskx ? Monitor or Gcard ?
Regards, Super M
a c 193 C Monitor
a b Ô Samsung
November 21, 2009 1:26:47 PM
Video Drivers
November 21, 2009 2:23:21 PM
Hello,
I just finished reinstalled the drivers (latest). Still not working.. :sarcastic:
can any expert help me about this problem ??
Regards, Super M
a b C Monitor
November 21, 2009 2:35:29 PM
I still think the issue is with your Nvidia control panel. It can put a resolution cap on the windows display resolution. Depending on your version of Nvidia's control panel, it will look similar to this
http://nvidia.s3.amazonaws.com/screen01.jpg
November 22, 2009 3:07:25 PM
can any1 help me on this ??
a b C Monitor
November 22, 2009 4:37:17 PM
I don't know what else it could be. Everything I see on that model says it supports 1600x900.
I would try a different monitor and see if you can get the higher resolution. If yes, it's the monitor.
May 20, 2010 5:12:53 AM
well, i am too suffering from the problem........
i had some issues previously wid my monitor
after when i got it fixed, the problem was solved but my resolution became low..1.e 1280 x 1024
the same probs that your pc is showing, im not able to configure the problem.
i guess its the monitor who is having the problem.
ONE MORE THING
when i had XP 64 bit installed, i was able to add custom resolution to 1680 x 1050, but when i installed Windows 7, i am not able to install any custom resolution. i have installed all latest drivers, but still im getting the same probs.
i have 8600 GE nvidia graphic card
and 2043nwx monitor.....
can anybody give any solution
October 25, 2010 4:11:42 PM
whe ni go to 1900x1440x32 on the same nonitor ...... it gives me a "not optimum mode" message and the damn thing stays there for about a minute..... is there anyway i can disable that message
