Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Printers > HP pcs 1315v All-In-one Printer Problem
Forum Computer Peripherals : Printers HP pcs 1315v All-In-one Printer Problem
I have had this printer for over 2 years, with out a problem, but now all of a sudden, It will begin to pull in the paper only half way through, and then the printer will alert me and say that there is no paper or that there is a paper jam and/or it will tell me to check the print cartridges. I removed the paper/checked the cartridges in another printer, and they worked fine. So then I restarted the printer yet again, it did it one more time.
This will happen every time that I turn the printer on, and when I hit the print button on the computer. The Scanner will work, but if I want to make a copy of something it pulls the paper halfway through and jams up.
Can this be fixed, or should I just throw it out the window and buy a new printer?
Reply to orangejacob
Try using different paper -- thinner or thicker than present stock.
Reply to Anonymous
Still does It. Although it did not pull it through when I turned it on with the different paper.
If you can access them, try cleaning the paper rollers with a damp cloth. Again, if possible, check that any detector switches (some are optical) aren't obstructed.
It's hard enough to do this kind of maintenance on a standalone printer -- with a multi function device it's probably no picnic.
Reply to Anonymous
There are 1966 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1080 and 1200p monitors
By ssddx, 2 days ago:
hello again... remember that an actual screenshot comparing the two would be useless...
Best offers
