Network problems.......
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a small network. All the machine can see the Internet though my DSL
modem. They all live on the 'Z' network. When I use My Network Places and
hit "entire network" Z is found, and the other machines on the network are
found. Yet when I try to access those machines, I get told they are not
accessible and that ther are network path problems.
If I ping the machine it returns an IP, but fails. I do have access to my
local machine through My Network Places as expected, but they do not "see"
me.
Help!
How do I access the printer and files on those machines?
Thanks!
Ross
6 answers Last reply
More about network problems
  1. Archived from groups: microsoft.public.windowsxp.general (More info?)
    If all PCs are based in XP then:
    1) XP SP2 firewall is set to block pings.
    2) To share drives/files/printers, the user accounts must all be set up as
    they are on each PC. XP needs to authenicate each connection.
    "Ross M. Greenberg" <greenber@catskill.net> wrote in message
    news:11ffgb1f9i32dd1@corp.supernews.com...
    > and
    > me.
    > Help!
    > Thanks!
    > Ross
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    #2 isn't correct, if you have "Simple File Sharing" turned on. Then, you
    simply have to share the folder, and anyone on the network can access
    (Control Panel/Tools/Folder Options/View/(all the way at bottom.)
    Ross, also, if you don't have any folders and/or files being shared on the
    other computers, then nothing will show up.
    "Yves Leclerc" <yleclercNOSPAM@maysys.com> wrote in message
    news:%23qVOEkFnFHA.320@TK2MSFTNGP09.phx.gbl...
    >>DSL
    >> and
    >> are
    >> my
    >> "see"
    >> me.
    >> Help!
    >> Thanks!
    >> Ross
  3. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Thanks! Off to give this a try!
    "Head Hunter" <nospam@nospam.com> wrote in message
    news:Ojex%23vFnFHA.1416@TK2MSFTNGP09.phx.gbl...
    as
    > >>DSL
    > >> and
    > >> are
    not
    > >> my
    > >> "see"
    > >> me.
    > >> Help!
    > >> Thanks!
    > >> Ross
  4. Archived from groups: microsoft.public.windowsxp.general (More info?)
    No XP Firewall: we're Zone Alarmers. and even with firewall turned off, no
    luck in Mudville.....
    DSL
    > > and
    are
    my
    "see"
    > > me.
    > > Help!
    > > Thanks!
    > > Ross
  5. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Using Zone Alarm, have you configured the Firewall Zones to
    include the Router Range (192.168.1.1-253) ?, so that all the
    PCs in the LAN are "Trusted".
    The Range indicated is for example, and may not match your
    LAN range. Also, accounts without a password will not allow
    networking, as this is considered a security risk. Finally, all the
    PCs should be a member of the same workgroup - in XP that
    defaults to MSHome.
    news:11fh1a61fuil4ab@corp.supernews.com...
    >> as
    > DSL
    >> > and
    > are
    >> > not
    > my
    > "see"
    >> > me.
    >> > Help!
    >> > Thanks!
    >> > Ross
  6. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Even with ZA turned off and a reboot, I still get a network path error.
    "R. McCarty" <PcEngWork-NoSpam_@mindspring.com> wrote in message
    news:uAIb26MnFHA.2180@TK2MSFTNGP15.phx.gbl...
    > defaults to MSHome.
    no
    > >> as
    my
    > > DSL
    Places
    > >> > and
    network
    > > are
    > >> > not
    to
    > > my
    > > "see"
    > >> > me.
    > >> > Help!
    > >> > Thanks!
    > >> > Ross
Microsoft Windows XP
