Closed
XW6200 ultimate upgrade help?
  • Hewlett Packard
  • CPUs
  • Computers
Last response: in Computer Brands
November 18, 2011 5:11:31 PM
Hi guys I am going to max out my XW6200 I currently have one 3.6ghz CPU and I am going to upgrade it to two 3.8 ghz Xeon irnwindale CPU s (do they support multi threading?) just a quick question regarding the CPU itself as long as it is a socket 604 and 2mb cache and 800mhz bus does it have to be a HP cetified part or can I use other parts? Also does any one have any good ideas for a GPU I will be running windows 7/8 and adobe design suite and expression design. Thanks a lot guys :) ))
More about : xw6200 ultimate upgrade
a c 80 α HP
a c 1073 à CPUs
November 18, 2011 5:37:22 PM
Intel Xeon EM64T 3.8 Irwindale 3.8GHz Socket 604 does support hyperthreading!
November 27, 2011 10:46:18 PM
i HAVE THE xw 6200 i HAVE THE 3.4GHz and they do great with AVID and Adobe CS4
February 27, 2014 8:58:27 AM
Hi, did you manage to find out if the Irwindale chips work? Are you now on Windows 8?
March 10, 2014 7:13:51 AM
did it work, did you manage to get Windows 8 running properly on your xw6200?
