Cable tv signal
Last response: in Other Consumer Electronics
March 20, 2012 2:55:42 AM
Hello,
What makes my one tv say no signal and the other tv gets the signal in the other room
More about : cable signal
March 20, 2012 11:52:09 AM
There should be a break in the cable or the connectors. Furthermore, if the signal is not strong enough and you turn both TV sets on, then one TV set with a weaker signal antenna circuitry may give no signal message. Try the TV sets separately and if one set still yields no signal message, then check the cable and connections or have them checked from signal source to TV set. If you have a simple signal divider, replace it.
m
l
