I'm MAD!!! I have a serious network problem with my XP Pro (I had a Win2K Pro before and no problem with my network, and no, I don't wanna reinstall the W2K again... if posible). Here I go:
The computer:
Asus A7V with 1.2 Athlon
512 MB Ram PC-133
Hercules GForce 2 MX 32MB
Barracuda IV 40GB HD
Surecom Ethernet 10/100 card
The Network:
5 to 7 Computers (all Win2K Pro)
Connected to HUB 10/100
The hub is connected to a 3Com DSL Router as gate to the Web
Usual Network configuration, No Sub or IP problem (all OK and checked!)
The Problem (Help please!!!!):
I have the Win XP Pro Guest account enable to share some folders, but whenever someone tries to access my files, they windows explorer hangs!!! When I do the same and surf the LAN to access a friends computer the latency is notorious, after some seconds I click on the folder and the Windows Eplorer simple hangs. If I close the Explorer, everything closes and i get a nice empty desktop (no start menu or anything...), but if I start a new Windows Explorer without closing the first one (still "freezed" ) and I surf to the same network folder I can access the files!!! After 20 or more minutes the first Explorer gets out of the hang up by itself and I files can be accessed!!! My Win XP Pro is suppossed to be up to date.
Does anybody know what's the problem about???? Please help i'm desperate (I work in a LAN everyday and this is crazy!!!!). THX!!!!
<P ID="edit"><FONT SIZE=-1><EM>Edited by striker873 on 08/22/02 02:44 AM.</EM></FONT></P>
{D6277990-4C6A-11CF-8D87-00AA0060F5BF} - and delete it.
This is key that instructs Windows to search for Scheduled Tasks.
"Nix" <nmkolev@abv.bg> wrote in message
news:022c01c1d720$62ba33e0$3aef2ecf@TKMSFTNGXA09...
> Hi, I've got the same problem (I have posted a question on
> 27th here) and still haven't found any solution. I'll try
> to reinstall the XP without running the Network wizard and
> create the connection manually (as recommended sometimes
> in the Net's forums). I'll keep in touch. Good luck :-\\
> >-----Original Message-----
> >My XP Pro will sometimes hang when trying to access
> >network shares. The system eventually does wake up and
> >find the shared drive, a few minutes later though. The
> >machine is connected to a Win NT 4.0 network. I have
> >another XP Pro machine on the same network that does not
> >have the problem.
> >Any ideas?
> >Thanks
<i>It's always the one thing you never suspected.</i>
