G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I need some advice regarding repainting the cabinet for my SO76.
I picked up a few spray cans of Krylon paint as per Clay's site and did
a few test sprays to see how the colors matched up. The colors were
okay, but compared to the original paint, the Krylon was REALLY glossy.
Now, I don't have the means or the expertise to be using a spray gun so
I'm pretty much stuck with the aerosol spray paint method.
Were the original finishes on the cabinets fairly glossy and have
dulled over time, or were they more of a matte finish to begin with?
If I go ahead with the Krylon, is there any way to dull the finish a
bit....I was wondering if a Varathane matte finish top coat (sprayed
on) would do the trick, along with helping protect the paint?
I just want the finish to be as close to original as possible.
Any advice is appreciated.
Dave
Dave
