Tom's Hardware > Forum > CPU & Components > CPUs > HELP!!!! CPU slot tab broke
Forum CPU & Components : CPUs - HELP!!!! CPU slot tab broke
I was installing a new fan on my 1.4 Athlon when the center
tab broke off of the slot A chip seat. Can anyone tell me if I can replace the chip seat?? The fan only has one tab slot to connect too, which is in the center. I still have tabs on either side of the one that broke off. I could buy a new fan but wanted to know if there is an easier fix.
Thanks....!!
Sponsored Links
I don't think it is easy to fix it. Buy a HSF w/ 3 tab clip
Reply to andlcs
- 0 +
A fan with a 3 tab clip as suggested or if the motherboard is still under warranty, get it replaced.
<b>(</b>It ain't better if it don't work.<b> )</b>
Reply to Teq
Some heatsinks mount with all the tabs latched, you could look for one.
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
Reply to Crashman
Yea, thats what I figured.... Thanks
Reply to greengold
- 0 +
If you have a motherboard with the 4 holes around the chipseat you could get one of the Swiftech models that uses them.
Reply to Cuda
There are 1079 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
