How i can repair dell monitor model no 2005fpw
Last response: in Computer Peripherals
December 9, 2009 1:15:47 AM
No back light.
a b C Monitor
December 9, 2009 3:29:55 AM
Generally monitors aren't repaired. If it's under warranty, send it back. If not, you should look at replacing it.
Make sure the brightness is turned up.
December 9, 2009 3:41:45 AM
monitor is not under warranty.
a b C Monitor
December 9, 2009 3:50:02 AM
If all your color/brightness/contrast settings are adjusted, there's not much more you can do. It would be time to look for a new one.
Anonymous
a b C Monitor
December 9, 2009 11:11:20 AM
If you have the required skills, you might examine the power supply board inside the monitor for a failed (usually bulging) capacitor.
These are readily available at an electronics hobby retailer. Replacement is simple if you note the correct values from the existing capacitor and observe the correct polarity when soldering the new component in.
If you don't understand the above -- do not attempt repair but hand the monitor over to a skilled technician.
