Solved
Display problem with my laptop
Last response: in Laptops & Notebooks
Hey to all.
I have a hp pavilion dv5-1235dx laptop. the problem with it that its displays start to flickers as and when the laptop sees fit. I am worried because i do not understand why this is happening. The laptop is only about 7 months old (i bought it 7 months ago). The stupid thing that happened at the time of purchase is that i asked a family member to get me the laptop and he bought me a refurbished hp laptop. Now that the warranty is expired i do not what to do??????
Can anyone please point out what the problem might be???? Should i sell this laptop and buy a new one ??????
i should add that the flickering sometimes goes away when i move the screen a few times
My laptop specs are:
OS : win 7
PROCESSOR: T6400 2.0 GHz (Core 2 duo)
RAM : 4GB
HDD : 320GB
More about : display problem laptop
Best solution
Anonymous
Laptop Expert
Sounds like a faulty connector or cable. Check by connecting an external monitor if poss.
If it's a popular laptop model, a repair guy may be able to source secondhand parts, new may be prohibitively expensive.
Anonymous
Laptop Expert
I have the same model and had the same problem. Mine was under warranty however, so I sent it in to be serviced. When I got it back, they said it was a faulty cable/connector.
Ask the community
