Resurrect surround sound
Last response: in Computer Brands
January 1, 2012 6:37:27 PM
Hello,
i had a surround sound system from Dell with a huge and heavy subwoofer that powered the 5 speakers. subwoofer is now very dead (makes continuous bass noise that could raise the dead). altec lansing, no model number. says THX and lucasfilms (of all things) on the front. Is there any way to power the speakers without trying to replace this monster?
January 2, 2012 9:33:04 PM
Welcome to Tom's Hardware Forums!
If the subwoofer has a power adapter supplying power to the other speakers, then you must repair this power adapter or replace it.
m
l
January 11, 2012 4:05:33 PM
thanks, i figured as much. power seems to work. rain from a leaky ceiling dripped into the unit so i going to try to fix or disconnect the subwoofer connection.
m
l
January 11, 2012 4:38:50 PM
Yes, that will work. Good luck!
m
l
