Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
Because IE was trying to connect to a proxy server which are only used
on corporate networks.
Tom wrote:
> Thanks guys, I found another post that has solved my problem although
> I am not fully understood why.
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&selm=OnsJKNpGEHA.628%40TK2MSFTNGP10.phx.gbl
> joker <no-spam@netzero.com> wrote in message news:<#jW748aeEHA.1652@TK2MSFTNGP09.phx.gbl>...
>>Well since both computers are behind the router I'd say it is one of
>>several things. (I'm assuming that both computers are behind the MN-700
>>because you only refer to "http://192.168.2.1" for the router.)
>>1) A software firewall on the computer that can't connect is miss
>>configured.
>>2) The computers TCP/IP stack has been damaged.
>>3) There is some sort of one or more of the following on the computer in
>>question virus, spyware, mal-ware, &/or adware .
>>Some things to try from the computer that is having the problem. Have
>>it ping the MN-700 by both IP address & the name you assigned it. If
>>you get replies from the IP address but it can't find the server then it
>>is a DNS problem. I highly doubt that is the case since you said you
>>went to the IP address of the router.
>>I'm now out of ideas for now. I hope this helps. One other thing that
>>would help is the version of Windows that is running on the computer
>>with the problem.
>>Tom wrote:
>>>Hi all,
>>>I have recently reinstall my machine and it's longer able to get into
>>>my MN700 router for administartion. I am getting "Gateway Timeout"
>>>error from that machine when trying to go to http://192.168.2.1. The
>>>strange thing is I am able to go to the internet from that machine and
>>>to the router by
http://192.168.2.1 from OTHER machine. So it should
>>>not be the problem of the router itself.
>>>Any idea?
