Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > [Solved] Help bout monitor
Forum Computer Brands : Dell [Solved] Help bout monitor
Best answer from Saga Lout.
Hello,
my dell 1800fp wont come out of dsub safemode how do i fix it
Reply to shauna_88
Safe Mode or Sleep Mode?
Safe Mode is what a computer does.
Does the PC turn on OK? Fans, lights, normal sounds? Issues like this tend to be on the computer side, motherboard or video card dies, or the power supply. Test the PC with another monitor, it's probably dead.
------------------------------ Recommended Video Cards: http://www.tomshardware.com/review [...] ,3085.html
Reply to hang-the-9
The computer sounds fine the moniter just says dsub modde and wont do anything but a black screeni have had a couple flat screen moniters do this
Reply to shauna_88
Best answer
Does your monitor have a push-button menu of its own?
The only way the system could stick in a form of safe mode that only affects the screen is if /BASEVIDEO is ticked in System Configuration but that would still show an 800 x 600 on the monitor so everything is probably working properly except your screen.
------------------------------ Be it ever so humble, there’s no place like 127.0.0.1
Reply to Saga Lout
Another quick thought - is it connected by D-Sub - the small, usually blue 15 pin connector from the PC or does it have DVI or HDMI connections?
Reply to Saga Lout
Does another monitor work on the computer? Need to rule out PC as the issue. Can also move the monitor to another computer, see if it works there. Sounds fine, as in fans etc... does not always means it's working.
You can try to manually swap monitor inputs, if it's a newer monitor should have a couple of inputs and a bezel button to select them.
Message edited by hang-the-9 on 01-30-2012 at 07:05:48 PM
Reply to hang-the-9
ya its connected by a blue pin lookin thing,
Reply to shauna_88
The answer has to lie in the screen's own menu.
Reply to Saga Lout
There are 1963 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
