My android phone wont turn on and it doesn\'t have a battery
Last response: in Cell Phones & Smartphones
August 26, 2012 3:39:11 PM
My phone will not turn on and I'm charging and it doesn't have a battery, that I see
August 27, 2012 6:13:24 AM
Obviously you need a battery. Correct me if I'm misunderstanding your statement. Which phone is it?
m
l
a b Ë Android
August 28, 2012 12:44:12 AM
If I understand correctly, your phone does not have a battery correct?
Cellphones run off the battery 100% of the time. Even if your phone is being charged via a USB cable, the cellphone still draws power from the battery. The USB charges the battery directly.
It's not like a laptop where you can remove the battery but still use the laptop when connected to the A/C outlet. The phone needs the battery.
m
l
