Hi I'm currently running an 1800+ tbredA overclocked to a 2000+ on an asus a7n8x deluxe board. I have an antec case with two 120 MM fans in it, the front one blowing in, the back one blowing out. **Is this the proper way to have them??** I'm running a ti4200 video card, 2 80 JB WD hard drives, cd-rw, cd-rom, and an antec true430W power supply. I'm using some cheap comp usa HSF which worked fine in the winter, but i live in el paso tx and right now the temps are starting to rise. My idle temp is about 50C, and under load gets up to about 60C. When we start to have our 100F days in the summer, this isn't going to cut it. I have my computer in my room, i sleep with it on, so i'm looking for a quality HSF that's fairly quiet. I don't plan on overclocking anymore, but i need something quiet so that i can sleep at night and finally close my case. I know about the 7+ , but i tried that once and the speed settings didn't work at all, it was just full speed all the time and that was WAAAAAAAAAY too loud for me. Any other suggestions? I was thinking about the Vantec Aeroflow, any comments? Thanks in advance.
fiask0!
fiask0!
