Archived from groups: microsoft.public.windowsxp.general (More info?)
I have stopped getting sounds from inside the coumpter like a beep when I hit
"Caps Lock". The sound through the speakers is fine.
When I go to Control Panel>Device Control I get the worngin box "RUNDLL
An exception occured while trying to run
"C:\WINDOWS\system32\shell32.dll,Contro_RunDLL
"C:\WINDOWS\system32\USBAudio.cpl",Device Control"
"Steve Golden" <Steve Golden@discussions.microsoft.com> wrote in message
news:00EE31A9-DA9B-474D-BD4C-CDDA85C5A5C5@microsoft.com...
>hit
Hi Kelly,
Thanks for the help. Unfortunely you're over my head. I don't know what
"Start your troubleshooting with Creative" means. Am I in too advanced a
newsgroup? If so please direct me to the right place. In the mean time
could you explain what you mean. I have looked through old posts they all
seem to be about trouble with sound not comming from the speakers.
Thanks again,
Steve Golden
"Kelly" wrote:
> Hi Steve,
> Start your troubleshooting with Creative.
> All the Best,
> Kelly (MS-MVP)
> Troubleshooting Windows XP
> http://www.kellys-korner-xp.com >
> >hit
Apparently you have a Creative Labs sound card, so the advice was to go to
their website or technical support for help on issues that are specific to
their product.
"Steve Golden" <SteveGolden@discussions.microsoft.com> wrote in message
news2549CB8-4D06-45B5-8F5E-7710FAC16F80@microsoft.com...
> Hi Kelly,
> Thanks again,
> Steve Golden
> "Kelly" wrote:
>> Hi Steve,
>> All the Best,
>> Kelly (MS-MVP)
>> http://www.kellys-korner-xp.com >>
>> >I
>> >hit
On Wednesday 10 August 2005 08:08 am, Steve Golden had this to say in
microsoft.public.windowsxp.general:
> Hi Kelly,
> Thanks again,
You aren't in a very advanced newsgroup at all. If you were, the poster who
"answered" you would have learned how to properly express herself and
learned that top-posting is frowned upon in UseNet.
Have you been MicroShafted today?
To mess up a Linux box, you need to work *at* it.
To mess up a Windows box, you need to work *on* it.
D.
Thanks, I feel stupid I didn't realize that Sound Blaster was a Creative
product or that was even the name of a company. Seeing how I didn't mention
Sound Blaster I wounder and am impressed that Kelly knew. Is it hidden in
the wronging? Anyway I am now trying to find the answer through Curative's
site. However I think there must be some switch not turned on because there
are other sounds coming form inside the computer but not the one for the Caps
Lock. I looked in "Sounds and Audio Devices" on the Sounds tab under Program
events but do not find Caps Lock. Is it called something else? Is there a
was to get back to the default settings?
All the best,
Steve Golden
> their product.
> > Hi Kelly,
> > Thanks for the help. Unfortunately you're over my head. I don't know what
> > seem to be about trouble with sound not coming from the speakers.
> > Thanks again,
> > Steve Golden
> > "Kelly" wrote:
> >> Hi Steve,
> >> All the Best,
> >> Kelly (MS-MVP)
> >> http://www.kellys-korner-xp.com > >>
> >> >I have stopped getting sounds from inside the computer like a beep when
> >> >I
> >> >hit
> >> > When I go to Control Panel>Device Control I get the wronging box "RUNDLL
Kelly,
Sound Blaster I wounder and am impressed that you knew. Is it hidden in
the wronging? Anyway I am now trying to find the answer through Creative's
was to get back to the default settings? Having turned a couple of these on
I realize that these are sounds that come through my speakers. Not the
sounds that come from inside the computer case. What are those sounds, are
they also played by Sound Blaster? Do you known their file extension,
perhaps I could find them that way.
All the best,
Steve Golden
"Kelly" wrote:
> Hi Steve,
> All the Best,
> Kelly (MS-MVP)
> >I have stopped getting sounds from inside the computer like a beep when I
> >hit
> > When I go to Control Panel>Device Control I get the wronging box "RANDALL
> > An exception occurred while trying to run
I believe the ones you would be looking for are in .wav format.
Is it possible that you don't have a sound assigned to the caps lock
function?
On my system, it isn't even listed in the possible Windows sounds.
A Professional Amatuer...If anyone knew it all, none of would be here!
news854ED7A-895B-4E6E-A633-F40FF113B31F@microsoft.com...
> Kelly,
> mention
> Creative's
> there
> Caps
> Program
> a
> on
> are
> All the best,
> Steve Golden
> "Kelly" wrote:
>> Hi Steve,
>> All the Best,
>> Kelly (MS-MVP)
>> >I
>> >hit
>> > "RANDALL
You are most welcome, Steve. To clear things up, I would suggest starting
with re-installing the software for your sound card. In addition and in the
meantime:
To use the Regedit: Save the REG File to your hard disk. Double click it
and answer yes to the import prompt. REG files can be viewed in Notepad by
right clicking on the file and selecting Edit.
> Hi Kelly,
> Thanks again,
> Steve Golden
> "Kelly" wrote:
>> Hi Steve,
>> All the Best,
>> Kelly (MS-MVP)
>> >I
>> >hit
