Archived from groups: microsoft.public.windowsxp.general (More info?)
I've just been trying to reinstall an OEM version of XP to correct some bugs
in my PC. When I get to the point of entering the product key it says it is
not valid. I'm pretty confident the software is genuine - holograms etc are
all as they should be, etc - but the original installation of XP on the PC
seems to be different to the product key I'm using. I'm wondering if an OEM
version will not install without a hard drive re-format if there is an
existing version of XP already installed. Or is this just a problem with
the validity of my product key? If the latter, what can I do about it?
Michael
"Chris" <toffdool@bigpond.com> wrote in message
news:uMMa2UanFHA.3316@TK2MSFTNGP14.phx.gbl...
> bugs in my PC. When I get to the point of entering the product key it
> says it is not valid. I'm pretty confident the software is genuine -
> holograms etc are all as they should be, etc - but the original
> installation of XP on the PC seems to be different to the product key I'm
> using. I'm wondering if an OEM version will not install without a hard
> drive re-format if there is an existing version of XP already installed.
> Or is this just a problem with the validity of my product key? If the
Chris,
Are you doing a windows repair or a re-install? If you are trying to
install another copy of XP over an original you will run in to problems. You
should reformat. Another basic check is to make sure you are typing the key
in correctly.
You need to examine the Product Key very carefully. It's awfully
easy to mistake a "B" for an "8," a "G" for a "6," an "S" for a "5," or
a "Q" for a "0" or "O." Fortunately, Microsoft had the good sense to
leave the "1's," "I's," "O's," and "0's" out of the equation. Also, be
sure that your <CapsLock> is _off_ while entering the Product Key --
this isn't supposed to make a difference, but I've seen it do so, on
rare occasions.
