Yes No
Ads
Tom's Hardware > Forum > Home Audio > General Discussion > How to connect a RCA audio plug to a subwoofer with regular speaker wire?
Forum Home Audio : General Discussion How to connect a RCA audio plug to a subwoofer with regular speaker wire?
Hello,
I had a Panosonic surround sound system, I broke the receiver. So I went to Best Buy an I bought a yamaha receiver. The receiver requires a audio pin input for the subwoofer but the subwoofer i only has speaker wire. I went to Radio Shack and they sold me some Solder-type Phono Plugs, I cant figure out how to connect them. Can someone help me out.
Reply to poohbear21577
It's a bit difficult to determine what you actually have, based on your description.
1: If the subwoofer does not have a built-in amplifier this may not work.
Q: does the subwoofer connect to a 110v wall plug?
2: sounds like your receiver has an RCA phono plug output for the subwoofer, and your subwoofer has a phono-plug input.
A: Radio Shack should be able to sell you adapters to make this work.
hope this helps
-joe
Reply to joetekubi
poohbear21577 wrote :
Hello,
then this subwoofer may not be an active. am i right about that?
Reply to MEgamer
There are 1979 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
