DVD ?
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I do not have a DVD in my current Dell. Am configuring a new system.
I need to burn both CD-r's and DVD's. Will a single drive actually do
both? Will I regret not having dual drives? Will the software
supplied with the new Dell be adequate for simple backups to either
CD-R or DVD?
Thanks for your input.
~k
G
Guest
Guest
"Kmee" <Kmee@nospammsn.com> wrote in message
news:S9Rfe.473$Q15.5014@eagle.america.net...
> both?
Yes, a dual layer DVD+/-R/RW drive can handle it.
Perhaps but probably not. Drive failure would be as bad as it gets, and the
drive could be replaced quickly and fairly inexpensively.
>Will the software
> CD-R or DVD?
Yes.
Stew
curious
89
>both?
AFAIK, all dvd burners also burn cd.
Go here and check the burn function you want to get a list of dvd
burners:
http://www.videohelp.com/dvdwriters
LG GSA-4163B has good reviews and price may drop once LG GSA-4165B
comes out sometime this month.
www.newegg.com has good prices on burners.
>CD-R or DVD?
>~k
G
Guest
Guest
In article <S9Rfe.473$Q15.5014@eagle.america.net>, Kmee@nospammsn.com
says...
> both?
Oh, yes indeed. The Plextor PX-216A is one of the best possible
drives to do this.
I have no idea. Having dual drives does help with a little
redundancy, if one happens to go pafooey, but that's a choice you'll
need to make.
> Will the software
> CD-R or DVD?
I have no idea what Dell is supplying these days, but I question
the value of CD-R or DVD backups vs. time-tested and proven technologies
such as DLT.
However, it's your system, and only you can decide how important
having your data backed up is. Configure it how you wish.
Happy hunting.
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
G
Guest
Guest
Thanks.
~k
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:IlRfe.4303$7A2.2509@bignews6.bellsouth.net...
do
> both?
and the
>Will the software
> CD-R or DVD?
Yes.
Stew
G
Guest
Guest
Thanks for the info.
~k
"Curious" <Curious@curiosity.net> wrote in message
news:pe6081598t6bnlliiia6ov1c6nsjctklqc@4ax.com...
do
>both?
burners:
>CD-R or DVD?
>~k
G
Guest
Guest
Thanks for replying.
~k
"Dr. Anton T. Squeegee" <SpammersAreVermin@dev.null> wrote in message
news:MPG.1ce9cb699f169d81989725@localhost...
says...
system.
do
> both?
drives to do this.
need to make.
> Will the software
> CD-R or DVD?
technologies
such as DLT.
Happy hunting.
G
Guest
Guest
The 4163B is a great drive. And any DVD burner will burn CDs. The dual layer
would actually be a step up from a normal DVD burner inasmuch as it will
burn the new DVD dual layer media.
Regards,
John O.
> CD-R or DVD?
> ~k
