FM Antenna Input for coxial input?
G
Guest
Guest
Hello,
This may seem like a dumb question, but I have an old receiver that has only analog inputs and a coaxial input for an FM Antenna. I recently bought a TV that only has optical out. Would i be able to buy an optical to coaxial converter and plug it into the FM antenna spot on my receiver. It doesn't really make sense to me, but I figured it may be worth a shot. Thanks.
G
Guest
Guest
"an optical to coaxial converter and plug it into the FM antenna spot on my receiver"
Won't work.
Is the connection you're trying to make for TV audio through the receiver ? If so the TV may have an analogue headphone output or preferably RCA-type socket line output.
Either could be fed into the line input (AUX, TAPE) on the receiver.
