Tom's Hardware > Forum > CPU & Components > CPUs > Need to determine Power Demand many PC's/Servers
Forum CPU & Components : CPUs - Need to determine Power Demand many PC's/Servers
I'm in a position where I need to determine what the power requirements will be for about 45 PC's and 5 Quad Servers.
The monitors all have power requirements on the back such as 100-240 Volts, 1.7-.9 Amps but the PC's and Servers don't have any such information provided. I've tried to find this at the manufactures website (mostly Dell) but have be unsuccessful. Is there a rule of thumb a person can refer to when determining what the power load will be on a particular machine?
Thanks for any info.
Sponsored Links
Here's a VERY rough guide: <A HREF="http://www4.tomshardware.com/howto/20021021/powersupplies-02.html" target="_new">http://www4.tomshardware.com/howto/20021021/powersupplies-02.html</A>
There are bettter guides than this, this is just one that I happened to know offhand.
Knowan likes you. Knowan is your friend. Knowan thinks you're great.
Reply to knowan
- 0 +
Go here & do the math. It also tells you the general amps that are drawn & gives links.
<A HREF="http://firingsquad.gamers.com/guides/power_supply/" target="_new">Check it out!</A>
If it ain't broke, take it apart & see why not!
Reply to RCPilot
- 0 +
Thanks guys. That will give me a place to start.
Reply to moe669
There are 1303 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
