Hey people, left a post last night, got a response that was of much help. However I will have to apologize for just now thinking of a billion more questions I could have included. Hope you guys don't mind.
First on the agenda, Front Side Bus. I was told the for this was the speed of the interaction between the cpu and the other hardware components through the motherboard, Is this right??? As for the older model athlons (sub 2000 xp) the standard is 266? The newer models at 333, and the newer P4's at 533. Well my question here is performance difference between the 533 and 266. Its double the amount but does do you see a difference is daily usage???? (Keep mind I do alot of gaming and what not)
LoL another nOOb question, Cache. I was told it was on chip memory. Is it all that important? the difference between Barton's 640k and like XP 2000's 256k is it significant?
Amd Athlon 1700 0309 WHAT THE HELL IS THIS? LOL I ask this because I am feeling pretty bad right after the 2500 Barton vs. P4 debate. I know longer find the 2500 Barton worth the $175 when for that money there is the P4 2.53. Well, so heres a range of new questions. Undisputed amd rules lower price range, and I am thinking going a lower model (anything past XP 2400 or 2500 Barton too much money) and upgrading later on. Perhaps a XP 2000 or the new 1700 0309 (WHICH I KNOW ABSOLUTELY NOTHING ABOUT)
Is this a good plan? My question in this is well, it isnt the 512 cache and the 333 bus and I plan on doing alot of sound and video on this computer, can a lower model handle it? Yes, overclocking sounds like a very very tempting option. I have had my eyes on the Vantec Aeroflow for awhile. I think the possibility is definitely there.
Alright um Lol, appreciate any responses to this that is if you can make any sense of it.
Thanks,
Jake
Thanks,
Jake
