Intellimouse 1.3a erratic click efficacy
Computer is an old Dell Dimension 4500 desktop, mouse is the original that came with computer. OS is WinXP. Issue: Intellimouse clicks "work" fine (can hover, highlight, bring up query menus, etc.), then suddenly all clicks cease to register in computing environment. Cursor hovering is fine, however. Rapidly right- and left-clicking for a few seconds restores function temporarily, so clicks will "work" again, but only for a limited time. Mouse is firmly plugged into CPU tower. There are no cursor movement problems. Inside of mouse is gunk-free.
1 answer Last reply
More about intellimouse erratic click efficacy
  1. Hi pcamody
    If you have another mouse or can borrow one try it to see if you have the same issue . This will tell you if the problem is with the mouse or you have another issue . A new mouse may be a solution.
Mice Computer Peripherals
