Archived from groups: rec.games.pinball (More info?)
Hello; Mike here. Just got my CVB finished, and it works 100% except
for the ringmaster. When you turn on the game, the ringmaster just
continues to run, and you get the error message Ringmaster no reverse
motion. If you do the Ringmaster test it passes all of the tests. You
can run the motor both forward, and backward. Everything is working
except the ringmaster will not run in reverse when the game is
controlling it. Anybody seen this before? Any help would be greatly
appreciated. Thanks. Mike.
A couple things come to mind. I wonder if it would be worth doing a factory
reset just to clear up any odd things. You would lose scores or adjustments
you've made.
Next up, the harness that moves with it, and then switches or optos that let
the game know where the ringmaster is. Some things are powered different in
test so that could account for working in test but failing in game play. You
may have to go over it more thoroughtly to sort it out. LTG
"turbo" <hpu@comcast.net> wrote in message
news:1119642846.922752.17330@g14g2000cwa.googlegroups.com...
In the switch test do the switches for the RM register for up and down?
Sounds like you may have left them unplugged or they are out of
adjustment. Don
Don, and Lloyd; Mike here. Thanks for the replys. Everything is
connected, and works 100% in test mode. All of the switches are
adjusted exactly like the manual says, and are recognized perfectly in
test mode. In test mode you use the up, down buttons to run the
ringmaster forward, and reverse, and it works perfectly. The only
problem is that there is no reverse motion when game is turned on, or
in game play mode. I believe that I was told that the control voltage
will drop to zero for a split second, and that signals the board to run
the motor reverse direction. I was just hoping that someone had seen
this before. Mike.
Well I would test the J1-1 and 2 to see what signal you get in test
mode then see if you get the same when you boot and the RM is
self-tested. No signal :move to the P/D board J10-4 and J111-6 for the
signal. Looking at the manual. You will have to work backwards to see
where it got lost. I can open mine up and compare notes if that might
help. I still think it is something with a switch. Have you tested the
RM switches in the switch edge test? Are more than one activated?
Reseat the roms? Don
I’ll bet the directional drive, solenoid 39 is not working. During
ringmaster test when you push the + and – buttons changing the
direction of the motor, it may appear as though the motor is reversing
direction, but my guess is the motor is in fact only turning one way.
So get your multimeter out, put it on the yellow/white wire on the
motor drive board that is J1-2, then get into your solenoid test menu,
select solenoid # 39, verify you have 12vdc at this point that
momentarily drops low as you do the solenoid test. This is your
direction drive, when low motor is going to run one direction, high it
runs the other direction, but during this test the motor will not be
running, but voltage should switch. If this voltage is not switching or
not there at all trace back to driver board J110-4, if not working
there possibly the driver IC on the driver board U3 ULN2803 could be
bad
