Digital Sender
G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
Hello Newsgroup,
I need a little help on buying some hardware.
I'm looking for a box acting like the widely known "HP Digital Sender".
The newest revision is 9200. The price is more than 3.000 EUR. Is here
anybody, who knows a cheaper system, which has nearly the same features
(esp. PDF-sending of scanned documents via email?).
Thanks in advance,
Bastian Ebeling
G
Guest
Guest
<bastian.ebeling@gmail.com> skrev i en meddelelse
news:1115024501.348810.23030@l41g2000cwc.googlegroups.com...
> Hello Newsgroup,
HP Officejet 9130 and Laserjet 4345mfp (especially if you buy the optional
DSS 4.0 software) will give you some off the same features (+ a
printer/copier). Both at lower speeds than the Digital Sender. What are your
exact needs in terms of scanning and volumes?
Esben
