TECH: Mr. and Mrs Pac Man sound weirdness
Archived from groups: rec.games.pinball (More info?)
Finally got a Mr. and Mrs. Pac Man running that had a number of
problems. Unfortunately, in setting the sound options, I seem to have
lost the FX.
The MPU was replaced and all options cleared by loss of battery power
in that process. BEFORE I knew about setting option 18 in the setup,
I could get sound effects but no voice or waka waka sound. AFTER
setting option 18 to 03, I get voice and waka waka, but when you hit
something that should have a sound effect, the waka waka goes silent,
but there's no effect sound.
Any ideas why this happened, or what to check?
4 answers Last reply
More about tech sound weirdness
  1. Archived from groups: rec.games.pinball (More info?)
    The sound board has 2 volume controls... one for voice, and one for sound
    effects...
    did you check these...
    Philip
    "Vic Ireland" <vicNOS*P*A*Mireland@mindspring.com> wrote in message
    news:3qspb1pmgd0av4km7i60vgu4ssd1l830cn@4ax.com...
    > lost the FX.
  2. Archived from groups: rec.games.pinball (More info?)
    Yes, I've run both pots on the sound board to max and min a few times.
    The "sound" one is the one that does the waka waka and USED to do the
    effects. I used to have effects when rollovers and targets were hit,
    but no waka waka. Now I have waka waka, but no sound effects (just
    voice, run through the other pot).
    On Sat, 25 Jun 2005 02:58:53 -0400, "Philip Lathroum"
    >effects...
    >Philip
    >> lost the FX.
  3. Archived from groups: rec.games.pinball (More info?)
    IIRC there is also a switch setting that controls background sound
    effects. Used to have one, and lost sound (and some other things) when
    I moved the pin to the new house. Seemed odd that the switches were
    changed, but that's what happened. LOTS of vibration in the back of a
    moving van, I guess. Check your dip switches...
  4. Archived from groups: rec.games.pinball (More info?)
    All I found was attract mode sound on the hard dip switches. The
    "feature" sounds seem to be controlled by option 18 on the software
    setup. Still have no effects that I used to have before I turned on
    the voice.
Games Video Games
