Archived from groups: alt.sys.pc-clone.dell (
More info?)
Nicholas Andrade wrote:
> Sparky Spartacus wrote:
>> Joe M wrote:
>>>> Can someone direct me to a program or site so that I can transfer my
>>>> VHS
>>>> taped stuff onto DVDs
>>>> Thanks.
>>> http://www.pinnaclesys.com/
>>> I am using Pinnacle Studio AV/DV Deluxe v9 to connect a VCR to the
>>> computer.
>>> Capture, edit, burn to DVD.
>> I have the same config and am very satisfied with it. There are *lots*
>> of capture cards & editing/burning software on the market with people
>> happy with some of it. Look around, then you pay your money & make
>> your choice.
>> Are you planning on a straight copy or do you think you might want to
>> do some editing / consolidate multiple tapes onto 1 DVD, etc.?
>> Post back if you have any questions.
> I have one quick question, how does the input device deal with
> Macrovision protected tapes? I have a particular VHS that isn't
> available on DVD (and probably will never be), that I want to extract to
> my computer. I'm not even itnerested in burning to DVD, just
> transcoding with Xvid to put on my Xbox. Honestly, I'm not too
> interested on the software side (I'll be using Linux), but I need to get
> the media onto the PC first.
I didn't ignore your query, Nicholas, but I also haven't gotten the time
to experiment with it, either. Sorry.
