Yes No
Ads
Tom's Hardware > Forum > Home Audio > General Discussion > Fiber optic eliminate PC noise?
Forum Home Audio : General Discussion Fiber optic eliminate PC noise?
Hello.
I'm planning to buy a new amplifier to connect to my PC.
What i wanted to know is if you connect the amplifier to the sound crard of a PC via fiber optics, will the sounds (especially noises from the PC) will be eliminated?
I've noticed that if you connect good earphones directly to the sound card without playing anything you can hear various sounds that probably come from the fans, etc.
Thanks in advance.
Reply to fearnight2000
This topic has been moved from the section Opinions and Experiences to section Home Audio by Buwish
------------------------------ -Kevin
Can you access TH on your smart phone?
Reply to buwish
- 0 +
advantages of fibre
Greatly increased bandwidth and capacity
Lower signal attenuation (loss)
Immunity to Electrical Noise
Immune to noise (electromagnetic interference [EMI] and radio-frequency interference [RFI]
No crosstalk
Lower bit error rates
Signal Security
Difficult to tap
Nonconductive (does not radiate signals)Electrical Isolation
No common ground required
Freedom from short circuit and sparks
Size and Weight
Reduced size and weight cables
Environmental Protection
Resistant to radiation and corrosion
Resistant to temperature variations
Improved ruggedness and flexibility
Less restrictive in harsh environments
Overall System Economy
Low per-channel cost
Lower installation cost
so ye pretty much...
Reply to MEgamer
MEgamer wrote :
advantages of fibre
No crosstalk
Signal Security
Difficult to tap
Size and Weight
Thank you very much for your reply, you made things alot clearer.
- 0 +
but to send 5.1 signals they need to compressed, at that stage HDMI wins.
Reply to MEgamer
And if the audio of the computer has noise, the fiber optic connection does not remove the noise.
Reply to soundguruman
- 0 +
yes, but i think the OP is worried about interferences and such, and actual physical noise within the computer case, affecting analogue signals.
Reply to MEgamer
There are 1950 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
