Solved
Need help finding parts for project
Hello,
I'm currently working on gutting an N64 to run an emulator inside the original case and need some parts. I was told that HTPC parts might be the best fit for such a small case, I just do not know whats good for a cheap price. It will be running games only so the graphics card must be good. Any help would be much appreciated. I will need every part except for the case.
2 answers Last reply Best Answer
More about need finding parts project
  1. Best answer
    N64 case is too small to fit any type of gaming system in there. You may be able to run a simple computer in the case, just get a full board with built in CPU and video card. Although you said an "emulator" so I'm guessing to run old games in ROMs? You don't need a good video card for that.
    Like this http://www.newegg.com/Product/Product.aspx?Item=N82E16813157228
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813500065
    And a power supply for a gaming system will be the size of the N64 give or take, so no room for anything else. For a small system to run old 8-bit games on, should have no issues with a low end CPU and video card.
  2. Best answer selected by DMSchnoll.
Cases Graphics Cards Emulator
