G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Well, I'm a newbie by the standards of this group, anyway. I can usually pop
a case open and tell what's what, but I'm a little stumped here.
At work, our accounting-type person is working on an old Optiplex Gx1p,
Pentium II 450, with 128 MB ECC SDRAM (according to the setup utility).
We'd like to upgrade the memory on it to 256 or even 512 MB, if possible, to
avoid the frequent crashes that happen when there are four or five programs
open on it at once.
I opened the case this morning, and couldn't ... uh ... find the memory. The
CPU seems to be contained in a large black plastic sub-case, and there is
something that MIGHT be the memory clipped in flush to the motherboard, but
it's lying flat against the mobo and doesn't look like any memory I've ever
seen before -- very short (1.5 inches) and, like I said, flush to the
motherboard instead of perpendicular to it.
I was in a hurry, only having five minutes to poke around before the person
in question came in. Googling Optiplex GX1p gives me indications that there
should be three memory slots there, but like I said, I couldn't see them.
Am I going nuts?
Thanks for any help you can provide.
Matt Shepherd
open on it at once.
Am I going nuts?
Matt Shepherd
